Zebralight SC600 Mk II L2
Продам новый фонарь zebralight SC600 Mk II L2 18650 XM-L2 Flashlight Cool White
Месторасположение Кокшетау
Цена 20000 тенге
Main Features and Specifications
  • LED: Cree XM-L2 Cool White (Nominal CCT 6300K)
  • User Selectable Levels: 3 main levels (High, Medium and Low). Each main level can be programmed to one of its two sub-levels. The second sub-level of the each main levels can be further programmed to different brightness levels.
  • Light Output (runtimes)
    • High:         H1 1100 Lm (PID, approx 2 hr)   or    H2  670 Lm (PID, approx 2.5 hrs) / 356 Lm (3.9 hrs) / 162Lm (11 hrs)
    • Medium:    M1 70 Lm (30 hrs)    or    M2   32 Lm (66 hrs) / 12 Lm (172 hrs)
    • Low:         L1   3.8 Lm (16 days)   or    L2   0.43 Lm (2.5 months) / 0.06 Lm (4.6 months) / 0.01 Lm (5.5 months)
    • Beacon Strobe Mode: 0.2Hz Beacon at Low / 0.2Hz Beacon at H1 / 4Hz Strobe at H1 / 19Hz Strobe at H1
    • Light output are ANSI out the front (OTF) values. Runtimes tested (and parasitic drain estimated) using ZL631 batteries. Runtimes of the two PID controlled levels (1100Lm and 670Lm) vary greatly with ambient temperature and air circulation.
  • Operating Voltage Range: 2.7V - 4.2V
  • Battery: One 18650 size (up to 69mm long) 3.6/3.7V li-ion rechargeable. Batteries are not included in the package.
  • Parasitic Drain: Negligible (much less than the self discharging of a battery)
  • Beam Type
    • 80 degree spill
    • 10 degree hot spot
  • Dimensions
    • Head Diameter: 30 mm
    • Body Diameter: 25 mm
    • Length:   101.6 mm
  • Weight
    • 2.75 oz (78 gram) without battery
  • Features
    • PID thermal regulated outputs (1100Lm and 670Lm)
    • Battery capacity indicator (LED flashes 1-4 times, 4 short clicks to start)
    • Automatic stepping down from High to Medium, and from Medium to Low when battery capacity is low
    • Builtin over-discharging protection (2.7V cutoff)
    • Durable electronic soft-touch switch
    • Smart user interface provides fast and easy access to all brightness levels and beacon-strobes.
    • Precision machined unibody casing from premium grade  aluminum bar stocks
    • Proprietary heat sinking design bonds the LED board directly to the unibody aluminum casing
    • Durable natural hard anodized finish (Type III Class I)
    • Sealed and potted LED driver circuitry
    • Tempered optical grade glass
    • Orange peel textured reflector
    • Battery reverse polarity protection
    • Pocket clip
    • Lanyard ring
    • Waterproof to IPX7 (2 meters, 30 minutes)
Снижена цена до 18000. Могу отправить по Казахстану почтой за ваш счет.
Покупался с сайта производителя zebralight.com за $95, продаю за эти же деньги.
