Фонари
Народ, у кого есть опыт юзанья хорошего фонаря, какой он, этот хороший фонарь? :shum_lol:
Хочу прикупить себе Fenix, сейчас выбираю модель... Что посоветуете??
Как вам такая модель? 230 люмен..
Specifications
Model: TIABLO TL-1
Illumination: CREE 7090 XR-E WC Q5 LED
Max output: 230 Lumen (with 14500 li-ion battery)
Reflector: OP metal reflector
Circuit:constant current driver, with high efficiency dual mode DC-DC regulator (PWM / PFM)
function:multifunctional circuit with advanced Mini computer chip, and it can set according to customers’ variety requirement
Lens: Toughened ultra clear glass lens with AR coating
Body: Type-III hard anodize high quality aerospace grade T7075 aluminium construction, Natural
Battery: support 1.2V or 1.5V AA battery,and 4.2V 14500 Li-ion battery
Working voltage: 0.9V-4.2V
Switch: Forwarding tactical switch
Waterproof Capability: IPX-8 standard
Size: Head diameter 23mm, length 117mm
Net weight:128g
TIABLO TL-1 Unique Design
Special purpose flashlight for hunting, searching and explore
Long defending head,can be used as defending tool like break the window glass when in emergency.
Metal tracery tail cap, lifetime tail cap with best feelings with your hands.
Military HA-III anodizing, more reliable
Can be used as candle
Infinite Brightness Setting, set your own brightness, suitable for all kinds of use.
Multi-functional circuit( refer to instructions for details)
900mAH 14500 li-ion,high output for 45minutes, low output for(5% brightness)120 hours
High quality lanyard
или этот? 220 люмен?
The Fenix PD30 is a high-tech, rugged tool that's perfect for any lighting application. It features six levels of output, which not only allows the user to select the best compromise between brightness and runtime for any given task but also has ability to aid in an emergency. What's more, the Fenix PD30 throws an awesome 220 lumens beam, an incredible amount of light for a light of any size. If you're looking for a flashlight with solid reliability, digitally regulated brightness, and compact size, this Fenix is for you.
Features
Utilizes a Premium (Q5) Cree 7090 XR-E LED with a life of 50,000 hours
Two modes of output, selected by turning the bezel
General Mode: 9 lumens (65hrs) -> 70 lumens (8hrs) -> 117 lumens (4hrs) -> SOS
Turbo Mode: 220 lumens (1.5hrs) -> Strobe
33 days of survival use (2 continuous hours per day on the lowest setting)
Digitally Regulated for Constant Brightness
Low Battery Indication
Uses two CR123A battery (not included)
118mm (L) x 21.5mm (D)
Made of aircraft grade aluminum
Durable Type III hard anodized finish
49g (or 1.7 oz) weight (excluding batteries)
Waterproof to IPX-8 Standard
Push-button tailcap switch
Capable of standing up securely on a flat surface to serve as a candle
Battery not included
Includes a holster, a lanyard, two spare o-rings, and a rubber switch boot.
Operation
Fully press to switch on and turn the bezel to select the General Mode or the Turbo Mode. A soft-press anytime while the light is on will change the brightness levels of a certain mode. Keep the light off for over 2 seconds and the light will turn completely off, restoring the regulation circuit to the default setting.
В идеале хотелось бы такой заиметь, на 700 люмен :shum_lol:
Cree MC-E (M rank, WC) LED
Step up and down constant current driver, with high efficiency dual mode DC-DC regulator (PWM / PFM) and circuit to indicate the Li- ion battery from over-discharging. Working voltage is 3.7V to 12V, under the circuit flicker to remind users to replace battery.
Max output 700lumen, runtime: 45minutes( 1pcs 3000mAh 18650) and 3 hours (2pcs 3000mAh 18650)
Functions: one level output, easily to use and reliable
53 mm diameter x 50 mm deep reflector provides a greater efficient illumination over longer distances
Supports battery sizes; 2 x 3.0V CR123A batteries, 2 x 17335 Li-ion or one 18650 Li-ion battery
Type-III hard anodize high quality aerospace grade T7075 aluminum construction
Switch: Tactical forward switch
Weight: 230 g
Length: 175mm Head diameter: 57mm Housing Diameter: 34mm
 TIABLO Unique Design:
Special purpose professional flashlight for hunting, searching and exploring.
Unique body designs with excellent handling characteristics.
High quality brass copper pipe battery insert.
Due to the complex process used during the manufacturing of the rear lamp assembly, this ensures anti-counterfeiting.
If the flashlight head is removed, the light output is equivalent to a 25W daylight lamp which would illuminate up to 30 sq. metres
Military grade, durable, hard anodized finish in black.
Packaged presentation box with official certificate of authenticit
или вот этот........
Самый яркий фонарик в мире
Этот фонарик не зря носит звание самого мощного и яркого в мире – ведь он даже попал в книгу рекордов Гиннесса и его яркость составляет 4100 лм, что на 100 лм больше, чем у предыдущего рекордсмена. От может воспламенять бумагу и плавить пластик, и с помощью него даже можно поджарить яичницу. Работает он на специальном аккумуляторе и сверхъяркой 100 Вт галогеновой лампе, оснащен специальным огнеупорным стеклом, способным противостоять выделяющемуся теплу, а его корпус сделан из алюминия, использующегося в военных целях. Вот так вот все серьезно! Увидеть его в действии можно благодаря четырем видео (далее), демонстрирующих, как с помощью него можно поджечь бумагу и спички, подкурить сигарету или поджарить яйцо. Обойдется он в 300 долларов.
http://www.wickedlasers.com/lasers/The_Torch-74-0.htm офсайт
Ипать! 300 зеленых! Нафиг нужно. Лучше курковку взять. Сам маглайт АА и китайский налобник юзаю. Конечно маглайту до феникса далеко, но по цене/качеству он самый лучший. Не жалко, крепкий, светит нормально, яичницу я лучше по старинке зажарю - на плите, а на три сотни баксов можна Скирмиш вместе с Теном прикупить или часы хорошие, да вообще, купить много нужных вещей
На Ганзе есть ветка про эти фонари. Хвалят для самообороны по темнякам. Если светануть в глаза врагам в тёмное время - гарантированно минут 10-20 слепоты, зайчики и всё такое. Пользоваться ими надо осторожно - попадёт луч в какую лужу, отразится и сам зайчиков поймаешь.
Народ, у кого есть опыт юзанья хороегофонаря, какой он, этот хороший фонарь? :shum_lol:
Features
Operation
Пользую Fenix PD3 отличный фонарь, компактный, яркий, надежный. Отличается от предыдущих (показанных в первом посте) доступностью элементов питания - CR123A battery. Яркость можно выбирать от минимальной до очень яркой, слепящей.
Про зайчики от луж, чушь полнейшая, если себе под ноги не светить стоя в луже и при этом туда в упор не смотреть ничего не будет. Если напрямую в глаза светануть, то да слепит сильно.
Про лужи на Ганзе Ann писала, собиралась свой фонарь не менее мощный менять. Читал больше года назад.
Блин, для такого фонаря цена реальная помоему.
Давно хотел прикупить себе фонарик, теперь в серьез задумался.
Очень актуальная тема, сам давно хочу приобрести хороший фонарик.
Желательно в металлическом кожухе и с хорошей освещенностью, но согласен 300 бакинских цена для него неприемлимая)))
300 за самый яркий в мире фонарь, ну незнаю куда уж дешевле.
заявленные 4100 люмен это серьезно, имел счастье наблюдать фонарик со 100 люменами, уже впечетляет. для сравнения кто знает сколько этих люмен на дубинках маглайтах?
Я хочу взять себе Fenix PD30Fenix PD30, 220 люмен, обойдется примерно в сотню баксов. Я думаю, он стоит этого.
Вот как, все-таки стали обсуждать фонарики? :shum_lol: Тогда и я чуток поучаствую.
Одно время меня "зацепила" эта тема. Купил себе Surefire E2D (на 60 люмен, с питанием от двух 123-х элементов). Фонарь стоил 21000 тенге. К сожалению, его украли в прошлом году.
Позже в магазине НАТОвского снаряжения я взял китайский аналог "Шура" - Superfire. Он тоже на 60 лм., и обошелся мне в 5000 тенге.
Далее я все-таки обзавелся очередным "Шуром" - G2 (60 лм., 2х CR123A, цвета "хаки") - подешевле, за 6900. Кстати, оба "Шурика" брал в магазине на Чапаева.
А сравнительно недавно прикупил маленький тактический фонарик Fenix P1. Ну ооочень достойная вещица! Дает 90 лм. при одной батарейке 123. В конце концов, его пришлось отдать моей Аннушке :)
Хорошо, что в Коргане появились Фениксы, моделей семь-восемь разных. Можно пойти и пощупать, определится с понравившимся вариантом, который устраивает по техническим характеристикам.
Моя ИМХа. 4100 лм. за 300 долларов - это даром!! Те, кто в теме, понимают почему :shum_lol:
...давно хочу приобрести хороший фонарик.
Желательно в металлическом кожухе и с хорошей освещенностью...
Загляните в магазин НАТОвского снаряжения на Сатпаева (не доезжая Баумана, если двигаться от "микров"). У них неплохой выбор тактических фонариков от 10 до 20 тысяч тенге. Разных габаритов, с разной мощностью. В продаже имеются аккумуляторы типоразмера 123, и зарядные устройства к ним. Так же видел там кронштейны для подствольного крепежа фонарей.
К сожалению, не запомнил как точно называется фирма-производитель. По-моему, ТачЛайн. Это "китай", но ооочень достойный по качеству! (Просто я сам тактильно сравнивал с Шурфайрами. В целом, мне понравилось.)
А на какое реально время хватает батарей при таком свете.Чтобы не таскать с собой мешок запасных.На рыбалке в походе когда по вечерам только пользуешься.Или бывает возвращаешься в полной темноте к лагерю километров 5?
Светодиоды в экономичности рулят.
Видите, для одних 300 баксов за фонарь, пусть и самый лучший, неразумная цена, а для других чуть ли не даром. Вспомним, что для большинства обывателей, тысяча тенге за нож, расточительство и безумная цена. Отец увидел у меня Пенделя, взял посмотреть, видит "майд ин джапон" и с удивлением говорит: нож, наверное дорогой - не меньше тыщи стоит...
В этих-то фонарях явно не диоды,а при такой яркости жрет батареи наверное не меряно? Или нет?
Прошу у всех пардону за путаницу. Фонари, о которых я завел речь, называются NexTorch :shum_lol:
Мои "Шурики" на ксеноновых лампах. Ну да, фонарики прожорливые. Дык ведь они "тактики" же, у них функции-то какие? :shum_lol: Явно на роль "лагерных" не тянут. Для туристических нужд, да и просто для стабильного продолжительного света (пусть и не мощного) нужны принципиально иные фонари! :)
Задумался. Может, тоже такой фонарь за 300 баксов захотеть? Как чудо-феньку, а?
А что за элементы 123? Это АА?
Гость Almansur
2 Ханиф это такие толстые коротыши. кстати сколько они стоят и есть ли аккумуляторы под них. думал купить Inova X5. стоит в районе 30 баксов, водонепроницаемый, дизайн такой прикольный. там как раз 2 123 стоят
Изменено пользователем Almansur
Да ну, зачем он Вам такой сдался, с 4000 люмен? Этот "прожектор" впору военным, полицейским, спасателям, ну или охотникам использовать. Обычно фонарика с 90-150 лм. "за глаза" на все хватает! (Ну, желательна модель фонарика с регулировкой в сторону меньших мощностей.)
"Элемент 123" - это практически типовая батарейка для нынешних "тактических фонариков". Написание латиницей - CR123A.
...кстати сколько они стоят и есть ли аккумуляторы под них...
Самые дешевые 123-е в Алмате я брал по 90 тенге. В Армаде была супер-распродажа элементов питания Panasonic. А так они обычно в районе 350-400 тенге.
В принципе, этих (литиевых) батареек хватает порядочно. Главное, не упиваться бессмысленным свечением направо и налево! :shum_lol:
Да, я выше уже написал, что аккумы 123-е существуют (ЕМНИП, 5000 тенге стоит). Сам видел в Коргане и в БАЗЕ (НАТОвское, страйкбольное снаряжение) на Сатпаева.
